NickParker
When do I use LSI “G” breakers? I have a solidly grounded system. The fault current would be high enough that for ground fault, that over current protection also operates. Except where the code requires ground fault protection (like sockets & heat tracing), I plan to use just thermal/ magnetic overcurrent protection for all the breakers in the switchboard.
Also would like to know, What's in vogue?
