TEDstruc
- Dec 6, 2017
- 43
My situation is an S6x12.5 monorail that spans too far without some sort of reinforcing (24'-5") simple span without any lateral bracing between supports. My supervisor (not a licensed engineer) wants me to weld a W8x18 or similar larger beam to the top of the S6x12.5.
My question is how should I calculate the LTB capacity of the combined section? If I used the old ASD method of Fb = 12000 * Cb / Lb * (d/Af), it seems like I am limiting myself due to the increased depth of the section without accounting for any resistance to rotation from the top flange of the S6 and bottom Flange of the W8 (located near the neutral axis of the combined section). It's seams like the newer method in 13th or 14th edition may take into account weak axis stiffness and torsional/rotational stiffness and may yield a higher capacity.
A W14x22 (Sx = 29, Ix=199) by itself just barely works for this loading, and my combined section has just slightly lower section properties (Sx = 26.8, Ix = 192). But my gut feeling is that the combined section would be able to resist more torsional rotation than a W14x22 and if so, you could increase Lp and therefore increase LTB capacity.
Side notes - I may lobby to use a WT in lieu of a W-Shape to reinforce the monorail (thoughts)? A larger S-Shape for the monorail is not an option.
Any advice would be appreciated.
Thanks,
-T
Thanks,
-T
