LU decomposition
hoshang
IQ
Hi all,
I wonder why LU for this matrix retrieves such LU decomposition result.
M=
-0.5 -1 0
-1 -1 -1
0 -1 -0.5
L=
1 0 0
0 1 0
0.5 0.5 1
U=
-1 -1 -1
0 -1 -0.5
0 0 0.75
While it should be:
L=
1 0 0
2 1 0
0 -1 1
IDS said:
I can't help with Mathcad,
IDS said:
Your original post has one questioned that has been answered in detail.
IRstuff said:
You're just going to have to do your own LU decomposition.
My original post has one question that hasn't been answered.
Is there any workaround in Mathcad so that I can get hoshang results?
The question in the OP was:
to which the answer is:
IDS said:
there is more than one way to decompose a matrix.
The link previously posted:
has a good clear explanation of how to do LU decomposition, with and without pivoting, and why it is a good idea to use pivoting for general use, to avoid problems if there are any zeros on the leading diagonal. It also has Python code which will generate the unpivoted matrices (after applying corrections as posted above).
You haven't told us why you have to use the unpivoted matrices, or why it has to be done in Mathcad, but if both are essential for some reason, and if Mathcad doesn't have that as an option, it shouldn't be too hard to convert the Python code to Mathcad, or you could look at using:
or something similar.
Doug Jenkins
Interactive Design Services
IRstuff - it should be in the next few days. There will also be functions to call the Scipy linear algebra functions from Excel.
Doug Jenkins
PNatchwey said:
There is python library for LU decomposition.
The great majority of the code in my link is for calling the Scipy linear algebra functions from Excel, including the LU decomposition functions.
The Python routines were written purely so I (and others) can see how the process works, in response to the question in the first post of this thread.
Also note that the download file includes links to the pyPardiso library which is very much faster than the Scipy LU functions.
Doug Jenkins
Hi all
Any workaround using Mathcad.
As said on 22nd May:
Doug Jenkins
Similar threads
Replies
4
Views
349
