lube oIl pump both running
Ahmed Elzawawi
Bioengineer
Oct 9, 2017
15
I have problem to analyze in ethylene plant , main compressor RT-10 , when the operator turn main oil pump off the aux. pump delayed to takeover to pressurized the line , although the pump in auto- mode , my question how that happened and how i can start to investigate.
Hi Ahmed, You will have better luck with this question in: forum135.
Copy your post and paste-move it to the Chemical Engineering forum. This forum is more for biological engineering, not chemical process stuff.
When you're done moving it just delete this baby.
Keith Cress
kcress -
