LUSAS Smart combinations: show factors used for output
susurruspeanut
Hi there,
For smart combinations, you know how you specify the range of factors that can be used for each loadcase, then LUSAS finds what factor generates the most adverse effect? After processing, say if you want to view an M_y diagram for that combination (say max values), do you know how to get LUSAS to tell you what factors its applied to the loadcases to get to that M_y diagram?
Thanks in advance.
