Muhammad A
I have to connect 100kW 3phase load at a distance of 800 meter.Aluminium cable size will work? Is it feasible to run multicore aluminium cable as Voltage drop i calculated is too much?Regards
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You can get technical advise and sources for methods of calculating voltage drop on a forum, but you need to do the calculations yourself or get an experienced engineer to do it for you. You should not base the cable size solely on what someone on this or any other forum tells you.Muhammad A said:can you recommend size for above criteria
