stout1
- Apr 26, 2006
- 29
Everything that I have been taught and had proven to me shows that using the offsets in a machine is bad. Here's the way I have come to look at it. If it has been proven that the process is capable than there should be no reason to edit with the offset for production purposes. If parts are coming out of the machine out of spec than there must be something else wrong (ie, tool wear, chip build up on fixture, bad parts going in, etc.) What are others opinions about this? My current position is that if parts are not coming out to spec we need to find the root cause as to why this is, not to just adjust the offset in the machine to bring the dimension back. I am currently in disagreement with a production sup. with about 20 years with the company. Thank You for your opinion and letting me vent.
Michael
Michael
