I'm currently working on designing a front spring and strut package for a MacP car (S13 240SX). I'm trying to keep costs down and would like to go with a bilstein take apart shock. I know that I need to account for side loading and bending in the strut. And I was considering using a shock in an inverted setup with a steel or Al sleeve on the bottom that would slide with the shaft and go around the body of the shock to help deal with these loads.
I was wondering if anyone has any insight on this? I've seen several other setups for this car that don't use an inverted strut and don't know how they take into account the side loads. I mean that could do it internally but based on the size of the shock and the shaft displacement it doesn't look like there's any room for an extra internal guide. The shaft diameter might be a little larger in the front on some setups, but is that enough? I also seem to remember that the stock struts for this car seem to apprear very similar to the rear shocks in terms of shaft diameter.
This setup would be used for a track car, so loads would be an issue, but long-term (more than a race season) durability isn't as important. I just don't want to have something that will need to be rebuilt after every race.
I haven't done any of the loading calcs yet, I'm still in preliminary stages for this design and am really just trying to gather more information.
So I guess my main question is would there be any problems using a shock in a strut configuration? I would like to make an inverted strut to help with the side loads, but is it necessary? And does anyone know what type of extra support is designed into OE or aftermarket struts versus similarly sized shocks?
Tim
Tim
