[Macro CATIA] change cut view text
sigmacoder
MA
I'm currently working with CATIA V5, and i want to use Macros (VBA), but i have some problems!
My question is: how to change the text of a cut view? (see the picture)
i tried to use : myView.Texts.item(1) to access to this "text" but i think that CATIA dont consider it as text...
Thanks for your help,
hi ferdo,
my question is clear ... if it is a drawing text, why can't find it in the texts collection? this is my code:
Code:
Sub CATMain()
Set drawingDocument1 = CATIA.ActiveDocument
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item(1)
Set drawingViews1 = drawingSheet1.Views
Set drawingView1 = drawingViews1.Item(3)
Set drawingTexts1 = drawingView1.Texts
MsgBox drawingComponents1.Count
End Sub
that return 0, so the texts collection is empty ... if it's a drawing text , the collection shouldn't be empty, i should find it in this collection.
thank you!
Did you searched in v5automation file what it means drawingComponents ?
Bellow is a code which is searching texts in all your drawing, see what you can get.
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim drawingDocument1 As Document
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "CATDrwSearch.DrwText,all"
For i = 1 to selection1.Count
MsgBox selection1.Item(i).Value.Text
Next
End Sub
Fernando
collection.item(x).value will return the object in the collection
Eric N.
thank you ferdo, i didnt see your answer ... it's a smart solution, but :
will search in all the drawing document so it will consum lot of memory ... can i search just in the active view ? how can i do that?
Of course you can, just ask user to select a view, make it active in code, then use same code but instead of using
you can use
selection1.Search "CATDrwSearch.DrwText,sel"
or you can use the name of the view (if is a constant) then use same technique. The idea is to make first the selection...
Here is something which you can use also.
Fernando
