Macro deployment 1
Gilgamesh99
Automotive
MX
Hi:
Im trying to deploy some catvba macros (with userforms) with a catalog according to Mike Berry's deployment instructions. By this moment I've tried every workaround possible without success. The best result so far is when the catscript is opened with the catalog, then the attached error appears, click ok, and the macros window opens allowing to select the catvba macro. Is there someone here that can call a catvba macro with a catalog without errors.
The macros and catalog are placed in a server that every user can access. When I open the catalog and call the macro there's no problem, the problem comes when any other user try to do it.
Any help is welcome and appreciated.
I already tried that with no result. Can you explain how to do it?, perhaps Im doing something wrong.
well, the macros are in a server where the users can access any file. What do you mean by "same kind of installation"? if you mean the same catia versio, yes, everyone has V5R18.
What Ferdo wanted to know is if all user have access to this location from the E:\ drive.
Looks like something is not define properly in Line 29... Can you share some part of the code?
Eric N.
Here is the whole code to invoke a CATVBA with a Catscript:
Code:
Sub CATMain()
Dim param()
Dim oFilePath As String
Dim oFileName as String
Dim oModule as String
Dim oSystemService As Variant
Set oSystemService = CATIA.SystemService
oFilePath = "E:\USERS\marco12\Catalogo\" 'path where catvba project is stored
oFileName = "Tube_creation_V1.1_AW.catvba" 'name of catvba project
oModule = "Launcher" 'name of the module
Dim ss As Variant
Set ss = CATIA.SystemService
ss.ExecuteScript oFilePath & oFileName, catScriptLibraryTypeVBAProject, oModule, "CATMain", param
End Sub
Also, I dont know if having all the code in the form has something to do with the error (all the code is within the form instead of in individual modules).
Thanks again for your excellent support!!!
What OS you have installed?
If you are using Win7 with 64bit, catvba won't work.
Ask your IT to install Catia with 32bit.
Sundeep
Hi sundeep198
I dont know if you're refering to the fact that the deployment doesnt work because Im programming in Windows 7 64 bit and then copying the code in Windows vista is working perfect.
Your code to invoke catvba is correct, the problem is how the users has configured their paths to catalog location.
In my case, I saw users which had defined in same way like me the path to a certain location/server and for others in a different way (for example they don't have E drive...).
This depends on how your IT guys did the network connections. I saw also some other cases when they didn't install vba at all...or registration for CATScript and catvbs was done by default to DELMIA and not CATIA...
Fernando
So... there's no way to solve this problem without involving the IT guys?
