Hello guys,
I would like to know, if anyone of you have an idea how to write a macro which will do following.
I have Product with many parts and one part is (lets call it master) used for positioning all the parts (containing many axis systems).
Each part have only one published axis system and this master has also published all its axis systems.
Macro should do following.
1) user clicks macro button
2) Macro will ask to select part (automaticaly select coincidence constraint and published axis system from selected part)
3) User will select axis system in master file
Part is constraint. Done.
Alternative could be, that after slecting part macro will compare part's published axis system name with published axis system names in Master and done.
Thank you in advance.
