Macro to copy Filename to clipboard
rickyt
Automotive
Jun 26, 2002
239
Looking for some help to make message box disappear after a few seconds.
At the end of my script I would like the msgbox to show, but automatically close after 2 seconds without clicking the ok button.
I have changed my last line from a msgbox to a wscript popup to hopefully make it timeout after 2 seconds.
Here is the code:
Sub CATMain()
Dim doc1 as Document
Set doc1 = CATIA.ActiveDocument
Dim Choice As String
'display an input box asking for file name format choice
Choice = InputBox( "1 MyFile" & vbCrLf & "2 MyFile.CATPart" & vbCrLf & "3 C:\directory\MyFile.CATPart", "Choose 1, 2 or 3", "1")
If Choice = 1 then
'get base file name without extension
sString = CreateObject("scripting.filesystemobject").GetBaseName(doc1.FullName)
ElseIf Choice = 2 Then
'get Complete FileName
sString = CreateObject("scripting.filesystemobject").GetFilename(doc1.FullName)
Else
'get absolute path name and extension
sString = CreateObject("scripting.filesystemobject").GetAbsolutePathname(doc1.FullName)
End If
'copy variable to clipboard
Set WshShell = CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("clip")
Set oWrite = oExec.stdIn
oWrite.WriteLine sString
oWrite.Close
'MsgBox sString, ,"text copied to ClipBoard"
CreateObject("WScript.Shell").Popup sString, 2,"text copied to ClipBoard"
End Sub
Thanks,
Rick
You can do it very simple in vba but not in CATScript or catvbs...
Now, you can use workaround... example in catvbs
Code:
Sub CATMain()
Dim doc1 ''as Document
Dim Choice ''As String
If Choice = 1 then
Else
End If
oWrite.Close
delay = 3 'seconds
Set fso = CreateObject("Scripting.FileSystemObject")
Enterfile = "c:\Temp\temp.vbs"
Set shell = CreateObject("Wscript.Shell")
T = "Set Shell = WScript.CreateObject( """ & _
               "WScript.Shell" & """ )" & vbnewline
T = T & "wscript.sleep " & delay & " * 1000" & vbcrlf
T = T & "Shell.sendkeys vbCr" & vbcrlf
T = T & "wscript.quit"
 'writes temp file
Set OutStream=fso.CreateTextFile(EnterFile,True)
OutStream.WriteLine( T )
OutStream.Close
 'runs temp file
shell.Run ("""" & Enterfile & """")
msgbox "This message box will close after " & _
 delay & " seconds" & vbcrlf & _
 "Your value is " & sString, 64, "Self Closing MsgBox"
fso.DeleteFile EnterFile
End Sub
Fernando
- Romania
- EU
