Macro to generate the Report of Distance between the parts.
Abhi9154
Nuclear
Feb 11, 2014
13
This is my 1st Post in Eng-Tips.
From my past experience i have found many valuable information in this Forum.
I have an assembly which consist of nearly thousands of Plates(Parts).
I want to generate a report which consist of distance between the plates.
If the Distance between the plates is greater than 150mm it should be marked in a colour.
Report may be in xls or xml format
I know i'm being direct but i need this urgently!!!!!
Please Help.
Thanks in advance.
search "distance between parts" in this forum give me this one in 4th postion in about 1 sec
thread560-353269
Eric N.
Thank u So much for your valuable response.
I have a question here :
we can have a macro where the user can select the parts and reference to measure the distance?
you can do plenty of stuff with a macro, that could be part of it
Eric N.
I want to generate a report consisting of distance between the plates (parts)
if the distance between the parts is less than 120mm it should be highlighted..
please help me..
I have been struck while executing a Function,
I needed to calculate the distance between various parts
I compiled a macro which calculated the distance between all the parts according to Tree Specification,and Exported the Result in Excel.
But the Parts in the design are not according o Tree Specification.
Now the requirement is
I need to Ask the user to select a bunch of parts and run the Command which will calculate the distance.M struck here.
Please help!
