macroscopic material balance for a multicomponent system from the microscopic balance
agustinlave
Chemical
Jan 24, 2018
3
Hi!
I don't know if anyone can help me but I've been trying to find the deduction of the macroscopic material balance for a multicomponent system from the microscopic balance (continuity equation) but I wasn't lucky enought. I manage to find both balances but I don't know how to derivate one (macro) from the other (micro).
If anyone have any clue I will be so grateful.
Thanks in advance!
 http://files.engineering.com/getfile.aspx?folder=62f8bba1-0ff7-4a95-9ad7-4ac2e286c6a8&file=bcemicro.PNG
agustinlave,
This seems more like an academic exercise than a real world problem faced by a practicing ChE. Is it for school?
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Hi Latexman,
Thanks for your answer. The question might not fit here but it's not for the school :D. I'm currently working on a design related to mass transfer and I need to understand first how to get to the macroscopic balance.
It's more a mathematical issue than a ChE stuff. Anyways if anyone can help me it would be amazing!
Best, Agustín.
Maybe you should broaden your knowledge on material balances by researching approaches other than the reference you showed. A different approach used by other textbooks/references may just spark the solution in your mind. I learned material balances from Felder and Rousseau's Elementary Principles of Chemical Processes. There must be dozen's more.
Good luck,
Latexman
