Boris A
Nuclear
- Aug 29, 2018
- 4
Hi everyone
My hobby is antique engines which frequently come with magnetos. These magnetos can be over 100 years old and sometimes need thier permanent magnets "recharged". I have designed and built a magnet charger that has a single pole rather then two poles that is the more common design for chargers (see attachment). It has 160 coils of 12 ga wire wound on a 1" x 4" low carbon steel rod. It draws around 100 amps from a 12V car battery for a brief moment to charge the magneto magnet.
I would really like to know if there is a formula that could estimate the charging capability of this configuration. I know that amp-turns is a basic measure of its performance but how does the core rod dimension and material affect its performance? Also how does the armature structure design come into play?
The formulas B=µNI/l and F=(NI)^2μ0A/(2g^2) (where g is the air gap). seem to imply that core cross section is important as well as length and material. Is there an easy way to tell at what point the core saturates? And how does the rest of the structure affect its performance?
Is there a basic formula that I could use?
Thanks much!
Robert
Thanks much!
Robert
