Magnetic B-H Curves
SnappyP
Materials
Mar 12, 2008
1
I am new to the magnetics world, but working on a solenoid and want to know what type of equipment is used to generate B-H Curves. Also, who would be a leading supplier of that equipment and the estimated cost. The solenoid requires a little more (10%) pull-in force midway through its travel and I am considering a full anneal of the armature and pole piece, but I need a baseline of the existing parts as they are today. The pole is 1018 and the armature is 12L14 Steel.
Magnetic Instrumentation is another source
Plymouth Tube
You do not need much to record an AC hysterisis curve. I have used a low voltage AC source (adjustable transformer) and an oscilloscope with integrating function. The TiePie HS4, for instance, has a very flexible set of "functions" that can be used for almost any measurement.
The attached picture shows measurements on a toroid made from ferrite. The saturation flux can be easily calculated from the results. As can many other properties.
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
