Magnetic field in steel framework
jt83
8
We have a planar steel framework made of rectangular tube steel members. There is a long straight conductor running through and perpendicular to the plane of the framework carrying 2000 amps. We have a B/H curve for common low carbon steel.
Questions: 1) Is the magnetic field intensity at any point along a given RADIUS constant or does it get reduced by the steel members closer to the source? (See attached sketch.)
The steel members will absorb and re-direct the flux lines. It will not be constant along a given radius.
What is best way to determine the heat input into the steel? Do you sum the volumne of steel for the entire wall? What equation would I use to determine the flux density or directly watts/lb of steel?
AC current. The steel will be galvanized.
jt83: Your situation is more complex than it appears. I'm pretty certain you'll have to use finite element analysis (or find a consultant who can do FEA) to get an answer.
It's possible someone has developed a general equation to describe your situation, but I am not familiar with it.
jt83:
Assuming that you are dealing with an isolated bus pentrating a bulk-head of some sort (unable to view your scketch), you start by estimating the field produced by the buss wiring at the metal frame location. you can then estimate the induced current in the steel work and determine if saturation is occurring.
at a minimum the bulk head penetration adds a bit of impedence to the circuit and creates localized heating especially if you provide a closed path cor the induced currents.
seems like a lot of work was done on this in the early 1930's when poly phase power became popular and led to buss duct installations rather than each buss being run separately.
quite a few papers written on the subject where cylindrical penetrations were studied
