dbill74
- Feb 26, 2009
- 538
Got a magnetic flow meter installed on a reverse osmosis (RO) system and getting the occasional spike/drop in flow reading. That is to say when looking at logs, we are seeing a reading where the flow rate doubles, then drops to about half the normal flow rate. There is no ramp up/down to these flow rates, just a brief reading of excessive/low flow, before the readings return to normal.
The flow meter is downstream of a centrifugal pump with an output pressure of ~800 pisg. This water has NOT passed through the RO membranes yet.
What can cause a magnetic flow meter to spike like this? We are trouble shooting other issues and it has been suggested that air is causing our problems, could an air pocket cause this apparent spike in flow?
Pump is controlled via VFD.
