FireSprinklerDesignerTX
- Dec 12, 2022
- 2
I'm trying to figure out how to accurately input the PRV information in Autosprink and have hit a roadblock as far as adjusting the pressures, etc. I honestly don't have much experience in this and I am trying to learn this. I've designed several pumps but never one with a main pressure reducing valve after the discharge of the fire pump. System details are below
ESFR System - K16.8 ESFR's Operating at 52 PSI Each
Fire Pump is a 1500 GPM @ 85 PSI
City Water Pressure is 118 PSI Static, 94 PSI Residual, Flowing 2123.20 GPM
This is an existing building that we are modifying
Basically just looking on how I need to input the PRV valve and Fire Pump in Autosprink to be able to accurately calculate.
Thank you guys in advance!
