Web site is
which is the company that makes the synchronous converters/dynamotors that convert 12 volts, 24 volts, or 36 volts DC to 120 volts about 45 to 70 Hertz. A dynamotor was a World War 2 technology that had a DC motor and 1 or more DC generators on the same rotor - essentially a direct current transformer. A synchronous converter was simply a DC generator with 3 slip rings connected to the commutator so that it acted as an AC to DC autotransformer. The Rediline units use seperate AC and DC windings in the same slots.
has a 48 volt DC to 120 volt AC solid state inverter.
Back in the 1970s there was a product advertised in the back of Popular Mechanics or Popular Science. I think it was called an Altvolt or Altpower. Duquesne Light Company in Pittsburgh, PA installed these on nearly all of their vehicles to supply small amounts of 120 volt power. This was advertised as producing AC power. I believe that this used a high frequency 3 phase transformer that was tapped into the alternator's 3 phase power like wvbht's buddy did. The transformer stepped up to something like 150 volts AC and then used a cycloconverter (a bank of silicon controlled rectifiers) to convert down to 60 Hertz.
If you want to design and build one there are 3 things about automotive alternators:
1. The rotor has traingular pole faces to produce a trapezoidal waveform that is more suited for rectification. I have seen the patent for a DC motor that works this way - poor guy thought it up before silicon rectifiers.
2. I rebuilt the alternator for a Chevy Chevette that I had. The alternator had 14 poles. Expect surprises.
3. When rebuilding this alternator I had to clean copper oxide out of the diode bridge and put in Ilsco Deox to keep out any more oxide. The copper oxide was why the alternator was only 1/4 charging the battery.
Every time that I have hooked up an industrial machine with aluminum wire the aluminum wire was a 100% success story. The old Signal Corps method was to clean out metal oxides and sulfides with diagonal cutters or sandpaper so that all the wire strands will be conducting particularly when making a solderless connection. The Consumer Product Safety Commission version is to use Burndy Penetrox A, A13, or E in addition to cleaning the wire strands. CPSC endorses the use of #220 or #240 silicon carbide paper to get rid of aluminum oxide. If semiconductive grit will contaminate insulating surfaces I have found that #220 or #240 garnet paper works just fine. For fine stranded copper wire finer silicon carbide paper would be appropriate. Go to
for more information.
Burndy Penetrox A and A13 have zinc particles to help bridge wire strands and conduit threads. Penetrox E has copper particles. I like to use Ideal Noalox for conduit threads and grounding of aluminum boxes even though CPSC says that it is flammable - more readily available around here. Ilsco Deox is a nongritted electrical grease that is suitable for everything EXCEPT conduit threads. Do not use Penetrox or Noalox on flat to flat connections.
Mike Cole, mc5w@earthlink.net
450 Meadowlane Road
Seven Hills, Ohio 44131
