luke04167
- Jul 13, 2015
- 1
Currently looking into a new, insulated HW ring main.
For context, this is a minor demand run but of significant length, with the loading being primarily single-user hot hose points with the potential for upto 12-15 active at any one time (say 35cu.m/hr @ 8-10bar).
Obviously there are various options for maintaining sufficient backpressure, and I'm curious as to what the consensus is on what is generally the best solution or what are common mistakes that should be avoided.
For the current system, the site is using a reduced tank return run, coupled with a VSD on the centrifugal pump.
Other sites I have seen combinations of control valves, regulating valves, STD valves, VSDs, pressure relief valves......
