Maintenance Pack 1
SiW979
804
Does anyone know how to find what maintenance pack we are using from command line, file, registry. We know we can find this in the syslog, but we are doing remote installs and need to find this information in the back ground. We also know we can get the QRM details from env_print.
Any helpe will be appreciated.
Best regards
Simon (NX4.0.4.2 MP4 - TCEng 9.1.3.6.c)
Life shouldn't be measured by the number of breaths you take, but rather how many times it's taken away...
Simon,
In NX5 you can use
"%UGII_BASE_DIR%\ugii\env_print" -m
for NX4 one has to use other methods.
strings "%UGII_BASE_DIR%\ugii\libpatch.dll" | findstr /c:MP
Regards, Joe
Joe
Thanks alot for that, it works a treat.
Best regards
How do you run those commands ??? in a command prompt ??
Thanks,
yes or in this case we are running it as part of a script.
Best regards
all,
I did a call batch inside of my normal ug batch and collected the date-time-computername and the version.....
echo %date% %time% %username% %computername% >> n:\temp\dave\ugnx5_update.txt
"%UGII_BASE_DIR%\ugii\env_print" -n >> n:\temp\dave\ugnx5_update.txt
the test file read like....
Thu 07/24/2008 13:19:31.91 dave davescomputer
NX 5.0.4.1
