motorsportsdesign
Automotive
- Jul 23, 2003
- 90
Here is my plan....Start with a large fortune, then make a large V-8 2 stroke for sportsman dragster racing.
The basic scheme is a supercharged piston port design with 4.840 bore spacing so I can use big block Chevrolet crank and rods.
The foggy areas for me at this point are port design, since the 2 stroke design software that I have looked into so far is not a good fit for bores in the range of 4.0".
I will also need to find a source for a piston with a ring on the bottom, I wonder, can a ring on the bottom piston be forged? It seems that it would be a big undercut.
Last thought is if the engine would require expansion chambers to make good power as they might be rather bulky I will have to model that to see once I have the approximate dimensions.
Any thoughts would be appriciated.
Jonathan T. Schmidt
Jonathan T. Schmidt
