First post, I'm not an engineer but have a little experience with paying others for certification of minor mods.
Summary
How to go about adapting a FAA STC approved camera bracket.
The background.
There are numerous derigable camera brackets designed to fit on the belly of AS 350 type helicopters ("A Stars" or "squirrels") that allow the fitment of a range of stabilised camera gimbals such as a cineflex V14 gimbal.
The brackets are a "single pole" design where the gimbal is attached to the end of the pole so the gimbal is situated underneath the nose of the helicopter.
The pole is attached via a drop down "fin" at the front and a "clamp" on the skid cross tubes at the rear.
The pole consists of a straight section then a separate goose neck which hugs the curved nose of the helicopter. The goose neck achieves two things, it moves the camera forward about 18 inches and it raises the camera around 12 inches to achieve better ground clearance.
Between the end of the gooseneck and the gimbal there is usually a flat 20 inch diameter plate that serves as a vibration isolator. (it is actually two plates linked by with wire rope)
In respect to paperwork, the vibe plate is a grey area as it can be deemed to be part of the camera payload.
The fin, pole and clamp can be fitted in around 45 minutes. They are common and in use around the world on AS350s.
The Question.
New gimbals are being released that are slightly larger. The gooseneck part of the bracket needs to be redesigned to maintain ground clearance of the fatter payload. We can eliminate or change the heavy and large vibration isolator and make a new gooseneck.
Id like to do this outside of the manufacturer of the bracket to keep a point of difference (as a camera guy) to my competitors.
Assuming the new gimbals fit within the size and weight of the STC of the bracket, is it feasible for an approved engineering organisation to create a new gooseneck and vibration plate?
I'd need the approval to work with any AS350 type worldwide.
thanks!
Cameraguy
Summary
The background.
The Question.
thanks!
Cameraguy
