We are in need of a small prototype series (300) plates of 1 cm thick PE plastic with lots of round or slotted holes. The plate themselves are about 110x70cm, and the holes/ slot should have a 4mm opening. Total hole ratio should be about 30-50 percent. The edges and surfaces should be rather smooth.(We can alternativly use thinner stiffer plastic, though not brittle at 0 degrees C).
So far I've come up emtpy in my search for even an remotely economical method of manufacturing such plates. Any and all ideas most welcome and appreciated!
