evilchild
- Jun 11, 2013
- 6
I've been reading a lot of threads of manifold design but it is still confusing to me. Here is my problem:
I've a 4 inch inlet pipe which will bring in about 300-500 gpm of water from a pump. I need to design a manifold of about 7 ft length. We are going to drill holes into the 7 ft pipe to create orifices. I have to figure out the spacing and size of these orifices to get uniform flow rate from all the orifices. The pipe thickness would be 4 inches and the manifold will be used in vertical direction. Any help is greatly appreciate. Thank you
