I'm working on a design for a device that infuses a slightly viscous material (~7cP) through 4 small nozzles. The nozzles will be embedded into tissue and will likely have different resistance to flow. In order to eliminate the possibility that all of the material will flow through the needle with the least resistance, I thought I could address my concern by building a manifold that somehow controls the back pressure so that any differences in resistance through each needle would be negligible and will result in almost equal flow through each nozzle. Unfortunately, I can't increase the back pressure very much, so that might not be an option. Does anyone else have any ideas on how I can equalize the flow to each of the needles?
