Hol
- Dec 18, 2013
- 20
This is an electromagnet that has both poles on it's surface. Example .
When it's surface is in direct contact to a ferromagnet it generates forces up to 480 lb.
Now it's manufacture states that it's not possible to create a repulsive force... I would disagree and would ask you if this is true?
Assuming the surface has both N & S poles, bringing an equal electromagnet like it, and orienting it in such a way N meets N and S meets S, there should be a strong repulsive force( Assuming Power input on both is the same).
Or am I missing something here?
The manufactures statement: [highlight #EF2929]Can electromagnets be used to repel as well as attract?[/highlight]
As they are sold, minimal to no repel can be achieved as they are designed to attract. What is needed to repel is a coil around an iron core with no outer shell. This configuration places a north pole at one end of the iron core and a south pole at the opposite end. The electromagnets as they are sold have a south pole and north pole on the same end. One pole is on the outside ring or shell and the other pole is located on the center post or core.
Can they be repelled?
And is the repulsive force near the attractive force?
