Hi
The customer's maintenance engineer is requesting manual ball valves for manual steam isolation (double block and bleed). I have used gate and globe type (Spirax Bellows Seal) in the past with good result. I prefer ball valves as automatic steam isolations. Something like a Keystone KTM.
The idea of manual ball valves as steam isolations seems a bit strange to me. I have mentioned that the operating torque might be a bit high and ball valves are not meant to opened slowly, which is preferred on steam. We could use a geared hand wheel to help with manual handling, but are harder to find and reduce the compactness that makes ball valves great in the first place.
Maybe I need to be a bit more open minded
What's your thoughts?
Kind regards
Kind regards
