Manual Volume Dampers on Return and Exhaust Ducts
Igc15
1
It's usual to insert manual volume dampers before a diffuser in all supply ducts branches. Is this also applied for return and exhaust ducts?
it depends on if there is a need to balance.
For example, if you have a single VAV box serving a single diffuser, you don't need a damper. you only need dampers to balance flows between 2+ diffusers.
You also can have return or exhaust VAV boxes, BTW. Or if you have a single fan exhausting from a single hood, no balancing needed.
If you need to balance, and all air systems should be balanced, you need dampers at all outlets/inlets.
