Manufacturing replay problem
benkitcher
Automotive
Apr 3, 2006
I'm having problems with my manufacturing program when I try to play the toolpath simulation I am given the message "The stock part specified is not proper".
I have been working on this part for the best part of a week and its been fine, I have not changed anything with the stock part and now it has stopped working.
Any ideas why?
Thanks,
Ben
Hi there
Had this problem myself. It works ok but as the process gets bigger it will just crash. You can play with the settings in tools/options/machining/photo video. Set Tool/faceting to larger and set the slider bar to about 50. to start with.
Usually I just need the replay to save the CGR file for a second operation rough stock. Even if the video is crashing you can click the FF button (>>) and it will display the finished cut stock (but with no toolpath replay) allowing you to save the CGR.
Hope this helps
