marine cable inspection
jalover
42
Hi guys, Is there any particular items to be inspected for the ship's installation cables, i.e. solas rules or any other class rules. thanks in advance.
Look at ABS SVR 4/8/4 21. available at Eagle.org. Also IEEE Std 45 (Recommended Practice for Electrical Installations Shipboard) has quite a bit.
thanks for your help. i will check it out.
Hi guys, i need some technical advise about the refrigeration system. Is it possible to convert the cold storage from positive temp application say 5 - 10 deg C ( usually for vegetables & dairy products)to minus temp application , say -12 to -18 deg c. without chinaging the size of the compressor, evaporator etc. only change the expansion valve setting? this is only for food storage on board the vessel and not a cargo reeefer.
please to hear for any advice.thanks a lot.
You should know better- start a new thread for a new topic- in this case in Thermodynamics Forum.
