Martensitic Stainless Steel - NACE - Impact Properties based on API 6A
JHWC
Materials
Apr 12, 2015
122
Hi All,
I would like to ask what are the ways to find out which steels have poor impact properties.
For example, AISI 410 material is a NACE SS material that have temperature rating of P, R,S,T and U under temperature classification in API 6A. On the other hand, S41500 or F6NM which is also a NACE SS material, have temperature rating of K,L,P,R,S,T and U. What I understand here is that because AISI 410 has poor impact properties, therefore it won't meet the charpy test requirement based on temp K.
As such, how can I determine or conclude which materials have poor impact properties under certain temp?
Appreciated the help given here. Let me know if the content is not clear and require more explanation.
Thanks,
Jeffrey
For martensitic alloys (steels or stainless) it is one part the alloy and one part the heat treatment.
You can't just talk about 410, what is the carbon content and what the hardness after Q&T?
Many of these alloys are listed in multiple categories, because their properties can be adjusted over a range.
All martensitic alloys display a DBTT, the issue is if that temp is low enough.
Thanks Edstainless.
Noted with the information you have provided.
Cheer,
Jeffrey
