Serhiy2
- Nov 10, 2018
- 45
Good evening,
I'm working on a project where 8" masonry firewall needs to be added into existing building. Wall will be supported by cast in place pile foundation. I was thinking of eliminating concrete grade beam and going with reinforced masonry beam built completely above grade instead. Supported wall height is 22' in total which will be laterally supported at the top. Movement joints will be located at every second pile which are spaced 12' to 18' apart. Four courses high beam would most likely work strength wise (haven't checked deflection yet).
There are few concerns I have with this setup:
- Lateral (rotational) beam support at piles will only be provided by a dowel extending from the pile. I wanted to check this support condition and wondering what load would I need to design it to in order to achieve adequate lateral/rotational support at piles. I was going to take 2% of beam reaction and apply it laterally at the top of the beam elevation at pile.
- The reason I'm not designing it as deep beam is because deep beam will require a lot more reinforcement and consequently grouting. Also, in case of grade beam, rotational support at beam ends would also need to be evaluated for some sort of load.
Appreciate any feedback on this approach. Thanks
