Masonry cost estimating
Hunt007
9
I was wondering if anyone had a rough all-inclusive(materials and labor) estimating cost they used for masonry?
Looking for a rough cost, either per block, or square foot for a fully grouted 8" block with vertical reinforcement every 24".
I have the NCMA Tek's for material estimating, just nothing cost. I don't need exact numbers, just some rough figures I can throw around.
what about 700 Thai Baht per square meter, all in. So about US$21 per square meter = US$1.9 per square foot.
sounds incredibly low to me - I was thinking more along the lines of $10 - $20 per square foot. Apparently, labor is much cheaper in Thailand than here. Hunt007 - your cost is very much dependant on where you will be constructing your wall.
The location will be around metro New York, so I would imagine labor costs will be on the high side.
Its got a lot to do with location and total square footage of wall.
For an elevator shaft I priced recently I carried roughly $20 per square foot including horizontal and vertical reinforcement and grout fill at 24"c/c. For a lager job it would be less.
Well! In Thailand a block is 18" x 8" which is one square foot (is it? I'm more used to metric). So in metro NY I guess you don't lay many blocks per hour.
i think labor is just much higher in cost in new york than it is in thailand. think union wages and collective bargaining for starters...
