I have a 4'-0" deep Masonry Crawl space wall, below grade, that is on top of a continuous footing. Throughout its entire length, the masonry wall supports the shear wall from the building above. We are in Seismic Class "D", so the building shear walls do impose the seismic shear load into the top of the masonry wall.
According to Table CC-7.3.2-1 of the TMS 402-13/ACI 530-13/ASCE 5-13 page C-83 a "Special Reinforced Masonry Shear Wall" needs to be used in Seismic CLass "D".
In section 7.3.26 (a) and (b), page C-85, the maximum spacing of horizontal and vertical reinforcing should be one-third the height which is 16" in this case.
My question is, if this wall were only 12" deep, do we need to place the horizontal & vertical reinforcement at 4" on center? This reinforcement requirement seems to be an overkill as the wall gets shorter....? The CMU units are only 8" deep...
Does this basement wall really need to be classified as a "Special Reinforced Masonry Shear Wall" or can it be classified as something different since it is a crawlspace wall and not a building shear wall.
Any guidance and code reference would be well appreciated.
