Dengr1
- Apr 24, 2009
- 11
My apologies if this is a dumb question but I can’t seem to see the answer.
If I have a pipe with known length and cross section that is empty on one side of a valve and full of a known substance (Liquid nitrogen in this case) at a known PSI what is my flow rate as I open the valve up at the exit of the pipe.
Assume m(dot-in) = m(dot-out) with no phase change of liquid
