jdkuhndog
- May 1, 2003
- 68
I am trying to determine the HP for a little motor to rotate a hook. There is a gear around the hook which meshes with the little gearmotor I am using - there is a 6:1 ratio between the output gear on the gearmotor and the gear around the hook. The output gear on the gearmotor rotates at 12.2 RPM.
The hook will have a load hanging on it that is a cylinder in the vertical position. It is 2' in diameter and weighs 35000#.
This is what I have done:
Mass moment of Inertia (Im)= (m*r^2)/2
Im = (35000# * (1 ft)^2)/2 = 17500 #ft
RPM of hook = 12.2 / 6 = 2.03RPM
w = (2.03 * 2 * pi)/60 = 0.213 RAD/sec
a = w/t = (0.213)/5 sec = 0.0426 RAD/sec^2 (assume 5 seconds to accelerate load to full speed)
T = (I*a)/g = 17500 * 0.0426 / 32.2 = 23.4 ft#
T at gearmotor = 23.4/6 = 3.9 ft# = 46.8 in#
HP = 3.9 * 12.2/5250 = 0.009 HP (I have selected an 1/8 HP motor).
Is this done correctly ??? I didn't break things out into slugs, so I wasn't sure if this was correct.
Thanks for any input.
