Mass Printing 1
Hassle
3
It's been a while but I remember that we used to be able to to a mass printing of multiple AutoCAD drawings from Explorer, and I thought we did the same with SolidWorks. Now we can do neither. We're running SP 4.0 2010 on a 64-bit XP OS.
Thanks,
Steve
Windows Explorer or SW Explorer?
The right mouse click menu doesn't contain the Print command?
Alternative;
Drag and drop the files onto a printer shortcut, or open printer window.
Using the print command, either right mouse or icon, allows you to print a single document; we need to print the entire contents of a folder.
The drag and drop and RMB > Print methods, also works for multiple selections ... leastways it does on my machines.
You should also be able to use the Task Scheduler.
I tried it again and found that Right Mouse/Print does work, but only if you DO NOT have a Drawing open; you have to close out of anyting active.
Thanks,
STS
I use PAC4SWX which can retain a list of files to print or convert. Very handy.
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
