The Siemens integration guide suggests to use the master model approach. The guide suggests to first create your part (UGMaster dataset); this part is stored in the item revision in Teamcenter. Next, the guide suggests to create a UGPart dataset and add the UGMaster dataset to it as a component (the same way you build an assembly). The guide mentions that the UGPart dataset is stored in the same item revision as the UGMaster dataset. The guide suggests to create the drawing in the UGPart dataset, and not the UGMaster dataset.
Question regarding above info: Would the item number of the UGPart be the same as the item number of the UGMaster? Is this even possible?
Prior to reading the Siemens guide, my understanding was that the suggested technique was to create a separate item for the drawing which would be just the basic part number. (Example: 12345-1.prt for the part and 12345.prt for the drawing.
It seems you can do this three different ways. If you need to add a document to a parts list to be delivered with the unit, is it required that a separate "basic part number" item be created for the drawing?
Thanks,
Mike
Thanks,
Mike
