I have been asked to look at an alternate house foundation type. A soil boring and geotechnical report was done. An engineer recommended mini piles or helical piles. There is a good layer of sandy-silt ( 7' w/ N values between 20 and 32) over a weaker layer of silty - clay ( 19' w/ N values 4 and less). The owner doesn't want to use these piles because he said they only guarented them for 20 yrs. I looked at a mat foundation and if I can get uniform pressure is will be about what the insitu pressure is now at the bearing grade ( 500 psf @ -5'-0". The question, will there be settlement problems and is there a reference to use to use to ensure the mat is stiff enough to distribute the load?
