0nuno0
- Jun 13, 2011
- 3
I am trying to match the edges of 2 untrimmed surfaces, to a simple trimmed slab. But i m getting a bit confused.
When i apply the command Match Edge, and ask for G2....It does give me 0.0000 reading from the G2 deviation, on the options of that command, although weirdly it gives me 0,003 for G0 and something for G1 too. To begin with, i feel this is strange. i have G2 without theoretically having G0?...Ugh.
Now even more confusing, if i go to analysys and check the edge to edge deviation, it yealds G2 ok, as i expected, but gives me like 0,6 for G0 and some other value for G1. Why?
If i zoom close on the conctact edges of those surfaces, they look weird, and are not lying on the trimmed edge. I went to preferences and set the tesselation to fine, and i still see artifacts, which i think are actually real and not artifacts, as the G0 shows.
ANother thing that i dont really understand, is why, when matching edges, is it so hard for the software to give me G0=0.0000.... I suppose it should be trivial, even with not so good surfaces.
I send here the file, if anyone can please elucidate me. I m doing something wrong, i think.
P.S. curves are hidden on standard curve layers, in case u wanna use them, or see what i ve done in steps.
Thank you in advance
