Material parameters of Abaqus elements
Sh_19
NL
thread799-417414
Hi. I have a question regarding the reference post. I want to get the material properties of all elements individually using a python script for odb file. I have the same issue using the codes introduced here that I get the same material parameters for all of my elements. I read your solution to modify the .env file. Shall I use the code "import os"... in the env file? I have to change the main env file in the installation path or just make a new one in my current directory? And then I need to rerun the model to generate a new odb file? I will be thankful to get your comments.
The Abaqus environment files and their possible locations (read by Abaqus in particular order) are described in the documentation. You can make this change in the .env file located in the Abaqus installation folder. Just copy the original file first in case of problems after making the modifications.
