I am in the process of looking to purchase a coil of SA414-G that would be converted to plate and used in a pressure vessel. After discussing with the mill and the decoiler, they have both proposed the following:
In reading SA-414, SA-6, and ASTM A635, this does not appear to be the correct procedure. It is my understanding that the processor should supply a certified mill test report by combining the results of all tests.
I have a couple of questions for those of you who are familiar with this:
Looking forward to your replies
James
1) The coil manufacturer supplies the analysis of the chemical properties of the coil.
2)The processor will de-coil and check for visual defects and validate the thickness in four locations. While subdividing the material, the processor will remove the required number of tension test samples and send them to the lab of my choosing.
3) I (the purchaser) will need to combine the chemical analysis from the mill, the tension tests from the lab, and a report for thickness and visual verification from the processor, and then certify the plate as SA-414 grade G.In reading SA-414, SA-6, and ASTM A635, this does not appear to be the correct procedure. It is my understanding that the processor should supply a certified mill test report by combining the results of all tests.
1) Is the manufacturer certifying the material industry standard practice? (The material manufacturer and processor are well-known reputable companies with shops throughout North America, so I’m inclined to rely on their expertise.)
2)I am used to material verifications being the responsibility of a pressure vessel manufacturer, but I find it challenging to say that I, the purchaser, can certify a material to meet the minimum requirements of ASME Section IIA. Are there requirements in the ASME or ASTM standards for who is permitted to approve materials?
I also understand this is not that different from recertifying a material per UG-10 of ASME Section VIII, Division 1. THe diffrence for me is that in UG-10 I am recertifing based on a know material so I can certain of information such as the type of furnce used ect.Looking forward to your replies
James
