Materials not showing up in Assembly 1
Thanks CorBlimeyLimey, i've uploaded the file to here:
The assembly is called slug_bob, and the part with the material is called ball_caster.
(the assembly is missing the top jaw because the file is too large but the same problem applies to all of the other components )
The assy has been assigned an appearance (frosted plastic), which is overriding component level materials.
Thanks that was the problem, fixed it and now all of my materials are showing up!
