mathcad worth it? 4
wrantler
109
I have been using excel forever. It works for me...but I keep seeing these mathcad sheets and am intrigued by how easily laid out the sheets are. But then I seen the price of $700/year!
I guess I am looking for opinions on if it is worth the cost. These subscription licenses are making it hard for the little guy to make a business. I thought mathcad was a one time license for life..
On a side note has anyone used SMath? It seems like a free mathcad clone.
Mathcad also has a "Trace Window", but that's only used when programming & debugging. It shows the value of a variable "x" employed by a program when the "trace(x)" function is called.
With SMath, if I want to use a new variable, I often check it's value using the '=' sign. If it hasn't been used, it automatically assigns the equals ':=' sign. Also if I want to determine where a variable was first assigned, I use the '=' and let SMath provide a value. I then 'highlight' the variable and move it with the cursor upwards with the cursor (it shows a value, for example x=5in) until it goes 'blank' (for example x= ). That the location in the program where the variable was created. I'm also pretty selective in naming variables because I cut and paste the code from other programs.
dik, in Smath, one of the function keys (sorry, don't remember which one) will highlight where the selected variable was defined.
Thanks... didn't catch that. I will look... it appears to be easier. I often use that to find the first use (I do a lot of cut and paste); it works like a charm.
