Mating brackets to a cylinder
UofA2004ME
3
I am using SW2004. I am trying to mate 4 brackets to the outside edge(curved edge of cylinder). I need to mount the identical brackets at 0,90,180, 270 degrees. I have created the cylinder and the brackets as separate parts and I mating them to make an assembly. I can mate the brackets on the cylinder so they are concentric and the correct distance from the end of the cylinder but I can note get them spaced 90 degrees apart. Is there a function that will constrain the angular position of the brackets on the cylinder.
I think you can pattern objects, so you may not need to make four models.
OR, you can make surfaces of the brackets perpendicular to each other.
OR, you can make surfaces of the brackets parallel to orthogonal planes of the cylinder.
Mike Halloran
Pembroke Pines, FL, USA
Hopefully you created the bracket (you only need one) symmetrically about its origin and reference planes. If you did you can then use those planes to mate (constrain) to the cylinder, and either a Circular Pattern to create the other three positions, or again use the ref planes to mate to each other.
Thanks! I was able to get this done in 5 minutes this morning.
