megfourfun
- Sep 9, 2008
- 5
Hi all,
Im running vista and recording .wav files with the recording software offered by windows. I then import this data in matlab to process it.
When I plot the data "plot()" it returns the normal looking audio file plot (ill try to include an image). The problem is the file y axis max is from -.4 to .4 but the data exceeds these bounds. So, is there a way to fix this so that it includes all data (other than taking more samples at lower levels)?
Also there is a lot of unwanted data (no audio present). I need to remove this...edit the data so that it only includes the portion where actual audio recording is present.
Thanks in advance.
James
Thanks in advance.
James
