ME27272727
- May 15, 2014
- 88
Anyone aware of larger light-commercial DX split system / gas heat AHUs greater than 5-tons that don't require 3-phase power? It appears all the manufacturers typically jump from single to 3-phase after 5-tons. I'm working on an addition that has a large open space with 20-ton cooling load and high ventilation requirement, so hacking it up with multiple smaller residential type A/C units not a path I want to proceed with. The existing electrical service is a 240V/120V, typical residential type for USA. Seeing what my options are before investigating an upgrade in the electrical service.
Thank you.
Thank you.
