Max absolute value comand?? 3
SRO
Is there a comand to get the Max absolute value for a group of numbers. ie
1, 6, -14, 7 = 14
Type
Code:
=MAX(ABS(A1:A4))
and press Ctrl+Enter (enters it as an array formula). The formula now looks like:
Code:
{=MAX(ABS(A1:A4))}
Cheers,
Joerd
joerd:
Thanks, but the problem is that the values arn't in the same column or row.
Just separate the values with comma's:
=MAX(ABS(A1),ABS(B4),ABS(E19),....)
jproj
Unfortunately, you cannot use =MAX(ABS(A1,D9,F7,E12)) and select the cells holding the Ctrl key, what you would normally do. I see nothing quicker than =MAX(ABS(A1),ABS(D9),ABS(F7),ABS(E12)) unless you venture into a VBA function, which will look something like:
Code:
Function MaxAbs(ParamArray R() As Variant)
Dim C As Variant, V As Double
    V = 0
    For Each C In R
        If Abs(C.Value) > V Then V = Abs(C.Value)
    Next C
    MaxAbs = V
End Function
Cheers,
Joerd
Or make a table of the desired values....
Thanks for all the input, I was just hoping there would be a simple comand. Thanks.
Try combining Min and Max;
=MAX(MAX(A1:A4),-MIN(A1:A4))
I like needahandle's solution. Nicely done!
